AA Surplus web logo
BBB-1
Mon-Fri 7:30 a.m. – 4 p.m.
Plantsville, CT. 06479
New and Used Wire Decking in Plantsville, CT
Wire Decking for Pallet RackSized to Your Beams.
Standard channel decks for step beams, flared channel for structural and box beams, and in-step decks for hand-stacked loads. Shipped nationwide.
CALL 1-800-826-5326Call NowGet a Decking QuoteGet a Quote
★ 4.9 · 91 Google reviewsBBB A+ RatedSince 1939
What Wire Decking Does on a Pallet Rack
Wire decking is a welded steel mesh panel that sits across the front and rear beams of a pallet rack level. It turns two beams into a shelf. Pallets that hang off the back don’t drop through, cartons and loose parts have something to sit on, and a broken pallet board doesn’t send product into the flue space. Most warehouses add it. We sell it new and used, and we’ll quote it with your rack or on its own for rack you already own.
wire decking for pallet racking
Commonly Stocked Sizes and Capacities
Deck Size (Depth x Width) Fits Frame Depth Channel Style Waterfall Capacity (Uniformly Distributed) New or Used
42 in x 46 in 42 in 4 channels, 4 ga wire Front waterfall, 5.5 in extended rear lip 3,000 lb Used
Used decks come in as we buy out buildings, so the mix changes week to week. If your size isn’t listed, call and we’ll check what’s come in.
Three Deck Styles, Three Beam Types
Match the deck to the beam, not the other way around. Mesh opening, wire gauge and channel count change the rating from one deck to the next.
wire decking
Standard Channel
U-shaped support channels run front to back and rest on the step of a step beam, the common roll-formed beam on teardrop rack. The mesh wraps down over the beam faces (the waterfall), so the deck can’t walk forward and pallets slide on without catching.
wire decking
Flared Channel
Box beams and structural beams have no step. On a flared channel deck, the channel ends spread out and bear on top of the beam instead. If you run structural rack, this is the one you want.
wire decking
In-Step Wire Decks
These drop into the beam step and sit flush with the top of the beam. No waterfall, nothing sticking up. They’re for hand-stacked cartons and lighter loads, not forklift pallets.
Sizing Decks to Your Beams
Measure the frame depth first, outside of front column to outside of rear column. The deck depth matches it: a 42 in deep frame takes a 42 in deep deck, and the waterfall drapes over the beams on both sides. Then measure the beam length and the beam profile. Two decks usually fill one bay side by side, so the deck width is roughly half the beam length. Check whether the beam has a step. A step beam takes standard channel or in-step, and a box or structural beam takes flared channel. Send us those three numbers with your pallet size and weight and we’ll match the deck. On used rack, measurements and a photo of the beam end tell us more than any label would.
Capacity Ratings and Direct Loads
A deck’s rated capacity assumes a uniformly distributed load: the weight spread evenly across the whole deck, with the pallet bearing on both the front and rear beams. That’s how the number on our table is stated.
A load that doesn’t touch both beams is a different case. A crate set in the middle of the deck, a pallet turned sideways, a machine part on its feet: these are direct loads, and a deck rated for a given weight won’t necessarily carry that same weight as a direct load over time. Our own example from the floor: for 2,500 lb pallets placed as direct loads, the manufacturer’s engineers specified 3,500 lb wire decking. If your loads sit like that, tell us when you ask for a quote. Direct-load jobs need the manufacturer or an engineer to confirm the deck, and we’ll get that answer before anything ships.
Used decks carry A&A’s own conservative rating.
Decking and Rack Safety
Decking catches a pallet that’s been set short or has a cracked bottom board, which keeps product off the aisle floor. It doesn’t replace pallet supports or a load sign. Load signage and rack labeling are the customer’s responsibility; A&A doesn’t supply them.
New or Used
Used decking is the lower-cost way to fill a building. Ours comes out of warehouse buyouts. New decks make sense when you need a matched count in one size or a firm ship date.
Photos From the Yard
Most decking orders go out with rack. Our pallet rack sizes and capacities page lists the new uprights and beams we keep in the yard, and the used racking accessories page covers end-of-aisle protectors and the rest of the add-ons.
Shipping
We ship wire decking from Plantsville, CT to buyers nationwide, including the states below. Send your zip with the quote request for a freight number.
Connecticut
Delaware
Maine
Maryland
Massachusetts
Michigan
New Hampshire
New Jersey
New York
North Carolina
Ohio
Pennsylvania
Rhode Island
South Carolina
Vermont
Virginia
West Virginia
Our Google Reviews
Posted on Google Google
Steve Yagudayev profile picture
Steve Yagudayev
Google star 1Google star 2Google star 3Google star 4Google star 5Trustindex verifies that the original source of the review is Google.
I can’t say enough about this company! Jason was on top of it my order and made a delivery with installation with in one week. I would definitely recommend this company. Very professional. Thank you Jason for make it happen.
Mark Campbell profile picture
Mark Campbell
We've worked with A&A Surplus for years, and they continue to be a great partner. I had a very small, last-minute order for one of our customers in Connecticut, and Bryan took great care of us. Small orders aren't always convenient, but he turned it around quickly and provided excellent service. Since A&A is local, my customer was able to pick up the material, which saved both time and freight costs. As a fellow rack and shelving distributor, I really appreciate companies that go the extra mile, regardless of order size. Thanks again, Bryan!
Tony Mara profile picture
Tony Mara
The entire crew at A & A Warehouse was excellent to work with. Not only was I impressed by their excellent availability and stock inventory, but also by their clear and effective communication. They went above and beyond expectation, all within a fair pricing window. I would definitely recommend their services to anyone in the industry.
Michele Graziano profile picture
Michele Graziano
A & A Surplus did an outstanding job from start to finish. From the first point of contact through the completion of our shelving project, everything was handled with professionalism and attention to detail. They delivered exactly what they promised, and their team was incredibly accommodating throughout the entire process. Truly a great group of people to work with. I will definitely be using them again for future projects. Thank you to the entire staff for an excellent job!
Anne Mao profile picture
Anne Mao
We have worked with A&A Surplus on 4 separate occasions. For this new project, we required racking in a short time frame. Jim Ambrose, whom we have worked with previously, went above and beyond to help us with our order. We receive a quote and signed off on the order in a matter of hours. Thank you for helping our team stay organized. We highly recommend A&A Surplus as the go to equipment supplier.
David Kunsman profile picture
David Kunsman
Extremely satisfied with A&A Surplus. I had to relocate a warehouse and provide replacement racking for the new location. A&A Surplus helped me manage this process from my home location in TN. They were extremely communicative during the entire process and were proactive in helping me avoid some road bumps due to some oversights that I had made. Jim especially worked constantly to make sure that we had everything we needed, including last second adjustments, to begin our move and be ready for business. Thank you A&A Surplus for your dedication to your craft!
Zachary Garman profile picture
Zachary Garman
Working with A&A Surplus has been an absolutely great experience from start to finish. The purchasing process was smooth, communication was clear, and delivery was handled quickly and professionally. A special shout-out to Jason, who has been awesome throughout the entire process. He answered every question, made sure everything went smoothly, and truly went above and beyond. I look forward to working with A&A Surplus again and highly recommend them to anyone looking for quality products and exceptional service.
Raby's Ace Home Center profile picture
Jim at A&A was great to work with! Responded quickly and answered any and all questions that we had regarding our cantilever racking system. Looking forward to working with him again on any other projects that we have coming down the line.
Shahram Nazar profile picture
Shahram Nazar
Thank you for your impeccable service and professionalism!
Matt Carlson profile picture
Matt Carlson
Dan was easy to work with and got me everything I needed quickly!
FAQ
Wire Decking Questions
Do I need wire decking on pallet rack?
Not always. A full-size pallet that sits square on both beams doesn’t need it. Most warehouses add it anyway, for overhang, mixed loads and broken pallets.
Will used wire decking fit my rack?
It will if the depth matches your frame and the channel style matches your beam. Send the frame depth, beam length, a photo of the beam end and your load weight, and we’ll check the fit before you order.
Do you buy used wire decking?
Yes. We buy wire decking along with the rack and other equipment when a building is being cleared out. See we buy used material handling equipment or call 1-800-826-5326.
Is wire decking required by fire code?
Not by name. Fire codes care about how open the shelf is, and wire mesh is the usual way to keep it open. Ask your fire marshal about your building.
What are your hours?
Monday to Friday, 7:30 a.m. to 4:00 p.m. Eastern. Call 1-800-826-5326 or send a quote request, and we’ll confirm the order by phone.
Ready to Order or
Have Questions?
Our team is available Monday–Friday, 7:30 a.m. to 4:00 p.m. EST. We’ll confirm your order by phone after you submit.
